For a 626 engine you will have to swap cam gears. You also need to swap your valve cover and coil packs or purchase some 1.8 coil packs and fab a bracket for them. I have heard that the cam senor, crank pulley and crank senor need to be swapped too but I don't think that is correct.
i believe you do need to - i think the pickups arent compatible and the configuration on the triggers is different. i can try to find the old thread about it. it also depends on the year of 626.I have heard that the cam senor, crank pulley and crank senor need to be swapped too but I don't think that is correct.
