Hyrdo to cable clutch
aceaspade
Contributor
Mazda Mx6 FSZE
to the best of my knowledge there is not a mx6 that has a cable clutch stock, right? i ask because i want to convert mine to a cable system, has anyone seen or heard of this being done on mx6? the reasoning is that after i put my stage 2 clutch in, the throw out rod on the slave cylinder no longer disengaged/engaged the tranny and clutch. (the throw was to short) so i moded the push rod like many others have done. and it worked but i have a very small gap at the bottom of compression to put it in to gear and its a bit annoying, and every now and then i have to pump it to get it in to gear.( no leaks seen) it has ALL NEW PARTS, slave cylinder push rod, master cylinder, brake booster, reservoir, rubber and hard lines. SO back to the question on hand has anyone seen this conversion done are their any major draw backs to it besides preference?
