Hwy 9 Fun Run!
It's a one off ACT, that may or may not be put into production. I have the model number at home. I am the first car to have it. It's got the Organic street disc from the so called "Stage 1" with an extreme pressure plate to hold the high torque and still be very streetable. I am told it should hold well over 360 ft tq. (If I remember right, I can't look it up right now, could be more could be less)
KpaBap said:
Sounds sweet, hopefully not too grabby (2thumbs)
Good luck with it.
That's the idea with the street disc over the 6 puck or 4 puck design. Hopefully the clutch will slip rather then break the transmission. Better to break the clutch then the tranny, and I am pretty careful with it so I should be fine.
Have you touched the insides of the tranny at all? I'd be weary of the stock tranny's abilities considering the amounts of power you're gonna be running.
It's when the vtec kicks in. The MPG goes to s***.
I gotta go eat, then I'll post up here. Prolly about 45 min to an hour
