Mwah ha ha, bringing this back from the dead since I have some questions as do some other people. So I'm going to install an aftermarket fog light kit. Let me get this straight:
1. The blank switch may be replaced by a P5 fog light switch, and the harness is already there to plug into the switch
2. The wiring harness is installed on the 2003.5 MSP, but stops near the passenger headlight.
3. The relay that comes with the fog light kit should be installed after the fog light switch. Is there an obvious place for this relay to go (like where the P5 relay switch goes Mazda just spliced the wires together)?
4. Wiring from the harness at the passenger headlight to the fog lights is missing. Using the wiring from the fog light kit can be used.
The relay part is my only question on wiring. I know 4" fogs will fit, what's the largest you can go with the G3 brackets and stock 03.5 lip?
