Last year I became the primary driver of our 2008.5 Mazda 3 (was my wife's car previously, she now drives the new CX-5), and after a horrible winter constantly cleaning road splatter off the windshield, I discovered I hated the OEM wiper nozzles on the 3. The CX-5 has nozzles that shoot a fan-shaped spray of washer fluid all over the window, so I decided to look into replacing mine.
I know there are aftermarket kits out there that have the fan spray, but the bottom of the nozzle (where the hose connects) on those ones points straight down. The 2004-2009 Mazda 3 has a 90 degree bend in the nozzle bottom, so the hose connects from the side. If you use one of the nozzles that point straight down, you would need a few bits-and-bobs to connect the hoses. I read one thread (somewhere, not sure which forum) where someone recommended cutting holes in the under-hood insulation layer where the hoses attach to the bottom of the nozzle, so that nothing kinks afterwards.
To simplify the process and keep things as clean under there as possible, I decided to look for a fan-spray nozzle with a 90 degree bend in the bottom part facing the same direction as the Mazda 3's. I finally found one: the 2008-2012 Ford Fusion nozzle is virtually identical to the 2004-2009 Mazda 3 one, except it has the fan-shaped spray pattern.
I bought them through the local Ford dealership for about $10 each.
[Edit: if someone can tell me how to make images show up in my post, instead of just a blue hyperlink, please tell me. All I'm seeing are the blue hyperlinks you have to click on to see the pics...]
The steps to replace the nozzles follow...
