HOW TO: Tranny fluid change on MS3
ill have to do this this weekend
I did it today, the how-to is good. I used a Blitz funnel with flexible extension tube from Autozone for about $3.50.
I have not beat on it, but the initial valuation is s i l k y . I am hoping to avoid the 1-2 crunch I sometimes get in the heat of battle.
-enganear
is this the same for the mazda 3 na????? how much oil should it take?
I just did this today. I have a stock 2006 3 n/a. The drain plug on our transmission is pointed straight down to the ground so this eliminates having to remove the tire. It can drain without having to remove the plastic under guard. However, life is easier to get to the fill plug if you remove the plastic under guard and someone can feed some tubing from the top down to you underneath to put into the drain hole. 3 quarts of oil is needed; owner's manual states 3.03. I figure that .03 will still be left in there and I was close to correct. 3 quarts did the trick.
I did mine today @ 27,000 miles. Using a 3/8th drive breaker bar (sans ratchet) and a standard craftsman 24mm socket yielded no clearance issues. I left my wheel on.
I also left my Xcel intake on and had zero issues. I bought a hose/bottle combo pictured in the first post. Made it tons easier.
While it can be done with 1 person, I still had a friend help. I held the fitting inside the fill hole while my help fed bottles at the top. I also left the fill plug in when I drained the trans and it glub glubbed all over my floor. :)
How did it feel afterwards? Much much smoother. No lie. I can flat shift with no grindage at all.
I used the fancy s*** in the first post too.
Just did mine today. Feels silky smooth when shifting.
I ended up putting in 3 Quarts tho. Maintenance manual says MS3's take 2.6 qts. Anyone else notice something similar?
I noticed something today. When the tranny is cold and I make low speed turns I hear a lot of noise. When everything warms up it goes away.
Anyone else experiencing this?
hmm interesting
is it a bad thing that ive never changed my transmission fluid?
like never, and the car has almost 200,000 miles on it
might need to look into doing it one day, maybe thats why im having trouble shifting
I just got my 3 quarts of MT-90 from the UPS guy. I'm gonna give this s*** a whirl really soon.
I did it! But I made an error (hand)
The washer from the drain plug fell out into my drain pan, and I didn't notice. I drained the fluid and filled the tranny with MT-90 and torqued everything down, then I noticed the washer in the drain pan when I was pouring it into my oil waste pan.
I don't have any more MT-90, and I know removing that drain plug to put the washer on will cause a lot of fluid to leak out. I'll have to order some more. In the meantime, how dangerous is it to drive around without the washer in the drain plug?
The plug is torqued in, and I am not detecting any leaks. Feel free to call me an idiot. I already know I am one (hand)(hand)
Nevermind. I'm going to put the washer back on. I'll capture the fluid that flows out in a glass container and pour it back in. Everyone, learn from my dumb mistake!
Edit: Done. Ok. Keep an eye on the fill hole and the drain hole when you remove the bolts. Make sure you retain the WASHER on the bolt.
Thanks to the OP for posting an awesome guide!
Alternative tranny oil change approach...
I have some Rhino Ramps, and figured I'd try something different. It's important to know that these are the standard ramps - NOT the low profile ramps - I have to use 2x8s to get up them.
1) Get up on ramps (only if you have a 24mm socket - otherwise run to Home Depot first!).
2) Remove plastic underbody shield.
3) Make sure you can get fill plug loose (at rear of tranny), then remove drain plug (VERTICAL plug at front of tranny, NOT angled plug), followed by fill plug, and have a beer. These are both REALLY easy to access on ramps.
4) Replace drain plug, torque to spec, and use a pump to add 3 quarts of your favorite fluid (I used MT-90). You will NOT get any overflow out the fill plug if you put in all 3 quarts (assuming you are on level ground and using the same ramps I did). Don't worry about it!
5) Hand tighten the fill plug after 3 quarts are in, then get off the ramps.
6) Put a shallow pan under the fill plug and remove it. A very small amount of oil will drip out - I'd say maybe 1/2oz at most. I'd say you can actually skip this step and just tighten up the plug while you're on the ramps and be done with it, because you have almost exactly what you need if you put in 3 quarts while on those ramps. But, if you're anal like me and/or don't want to believe me, let the minimal excess oil drain out. My next change, I'll skip a few steps - I'll do step 8 after step 4.
7) Hand tighten the fill plug and drive back up the ramps.
8) Tighten fill plug to spec and replace plastic shield.
9) Go take her for a spin!
Note that I did this in my garage, NOT driveway, so the surface was level.
I had a crazy time doing this.
I did this in my driveway, using Rhino Ramps. It's indeed true that you can access the bolts easily from underneath. Once it was up on the ramps, I oriented myself the drain plug, and the fit was indeed tight. I was using a 1/2" driver with a huge socket, and with a bit of a magic wiggle, finally got it in. Once the seal was cracked, you can unscrew by hand.
Once I found the drain, I oriented to the fill. I don't know how the poster above me did it, but I would have said the fill hole is horizontal, underneath the angled bolt of death pointing up and towards the airbox. I confirmed this looking at the images, and it seemed to match up. The fill bolt also looks just like the drain bolt, 24mm with a little circle in the middle.
Also, without removing the fill bolt, when I removed the drain bolt the existing fluid POURED out of the tranny. It gurgled against the vacuum, like pouring out of a gallon jug, and funky fluid got everywhere. Fortunately my drain pan is quite large and it caught most of the fluid.
That done, I re-sealed the drain bolt, and got my redline MT90 ready. I got the same fill tube as the OP, but mine had a convenient measured funnel on top, i forget the specific name. It holds a quart. With a little grace and patience, you can fill the funnel, tuck it under the stock airbox, feed the hose directly into the fill hole, and twist the seal to start flow. Doing this, I fed all three quarts of redline in, minus a puddle (I also used a compressor to drive out as much fluid as possible). I also spilled a bit on my arm when I overfilled the funnel (hurrying because of rain, see below). On the last quart, just at the very end, the fill hole didn't accept anymore of the fluid. I would say it was 2.90 quarts in all - it didn't drip, but I was up on the ramps.
While I was filling the tranny, the heavens broke open and pissed all over me with torrential rain. I was already filling the tranny, so there was no turning back. That bit sucked, completing the job in the rain. I made sure that no water got into the redline, and the fill plug was dry when I put it back on.
Questions: Can someone confirm that the drain and fill plug are identical? I'm about to go drive it, and I sure hope I didn't **** that part up.
As far as the amount, most of three quarts is sufficient, yes? This is already kind of answered, but what's the worst that can happen if it's a tad over full? I'd prefer not to take the plastic underthing off again and crack the fill plug, as I don't like playing with the threads on these screws anymore than I have to.
Yay. Hope this was worth it. I'm still paranoid about doing things like this to my very expensive baby...
OH. s***. SON. (omg)
Before: Shifting was like sorting dried twigs and brush with a rusty rake.
After: Shifting is like buttered ninjas cutting silk with feathers.
It really does make a big difference; it's just so... greased. Light. I was having a "crunchy" noise and feel going from 1st to 2nd, really feeling it locking in. 4th to 5th was just difficult. While these problems have not gone away, the incredible new smoothness of the shift assembly as a whole really brings the notchiness out in relief. 2nd to 3rd is just warm butter..
After taking it easy, I really pounded it in my neighborhood with lots of stop signs, and I could move through the gears much more quickly, with more "snap", if that makes sense. Still notchy/crunchy, but greased and featherlite. Odd that it helps some of the transmission issues so much and others still just suck.
Now that I've done this, I just hope the TRZ rear motor mount and eventual short shifter and bushings will complete the silky smooth experience.
The following three mods are ranked in order of improving shift quality FOR ME:
1. Motor Mount (inserts in my case)
2. Shifter Bushings
3. Redline MT-90
You're in for a treat man!
Just did this and its super easy! (yes)
Took some pics for those that a bit confused as to which plugs is that you have to remove and location.
Heres my fill apparatus, its a 2 liter coke bottle cut, it screws in perfect! Very useful.
Here is what the plugs look like, Both are the same.
Here is the location of the plugs viewed from the front of the car.
Hope this helps someone! (rockon)(headbang)(drive2)
Awesome pix! Thank you for incorporating and enhancing my "Angled bolt of Death" terminology.
So what's your review? Totally worth it? After three weeks or so now, I'm still a buttered ninja. It's still sticky in the cold, but after heating up or on a day in the 50s or higher, so s m o o t h...
