How to? side turn.
1338
03 MAZDASPEED Protege
is there a how to on taking off the side turn signels off i want to take them off so i can paint then with niteshade im gonan try and do ALL the lights
I've had mine off, I think they just twist or something, I can't remember - tells you in your owner's manual
really? i must have missed that i did not see it int he manuel
You mean the ones in the fender?
Just apply a little force to one side of them (by guessing) and it'll pop out. Kind of hard to explain over a message board. No tools are needed.
Edit: I just looked in the manual, I don't see where it tells you how to take the assembly out... Just how to take the plug out of the back to get to the bulb (which is obvious).
I think there just clips that hold them in just becarefull pulling them out use something that wont mess up the paint I accidently pull one of mine out and all it is a clip that hold them in on the sides
mspdfreak said:
I read here that you just slide the light toward the front of the car, then pull it out.
that show you do it i did i in less than 5 sec. i have been pulling abd pulling it and it would not come off untill i did this
