sub for what? you know you can sub without actually posting in a thread, right? also, this is for a Mazda5, not the protege or protege5.
oh HOT DAMN! ever since i did this to the protege, this is EXACTLY what i wanted to do with the wife's mazda5. thank you very much!
Photos please! Very interested in these switchback turn signals.
bring this back from the dead
does anyone know how to add a switch while using the original head light switch for sport
i want to use my aftermarket fog lights with the cars original fog light harness
cause it seems that my add on harness cant support two 35 watt hid ballast
Any report on how well the Switchback LEDs handle the heat-load from the HID headlights? I want to go to Switchbacks but plan on also going to HID and don't want to fry my new turn signals...
you'll be fine just make sure not to have the leds on when you turn on your car cause it will shorten the life of the led
question about DRLs....
my DRLs are on my low beam and I wanted to run the DRL to high beam....
is the same as the http://www.mazdas247.com/forum/show...Rewire-fog-lights-as-DRLs-A-T-only&highlight=
Could the 10amp fuse with a corner clipped off be replaced with a plug in "add-a line" kit with an in line 10 amp fuse? I would think you could, and don't really want to solder (because I really suck at it) I used the "add-a-line" when jumpering the fogs in my 08 Honda fit.
