I've manager a few bodyshops for over 12 yearsavhed said:I have a lot of tiny black spots on my body paint. The bigger of them I have removed by finger nail. Some of the smaller ones I used Bug Tar to remove.
What can I use on the rest?
I believe this is road tar adhering because I have neglected to put wax on it.(I know : DUMB!!)
FTW said:I've manager a few bodyshops for over 12 years
First try using rubbing alcohol or gas line antifreeze as they are vertually the same, this works the best on tree sap.
If that don't work use a paint company wax & grease removal cemical.
Then if that don't work & your extreemly carefull you can use paint thinner. We using paint thinner use in in a small spot & wipe it off. then let it dry before you go at it again. Thinner will some time make the paint soft so don't over use & again be careful.
