How to remove the trottle cable.
1alpajack
protege
Hi I need to remove the throttle body and was wondering the steps to remove the throttle cable on a 2002 protege 2.0.
thanks
It's really easy just push down on the linkage for the cable on the TB to get slack in the line then pull the cable up until it lines up with the slot and it will slide out towards the firewall. Be careful with the plastic clips holding the cable to the bracket if you remove it.
