center piece, push the two vents up and grab inside and pull out. Disconnect the plug from the back of the button for the hazard lights. For the bottom, you will have to remove the lines that are connected to the climate controls from the plastic pieces from either side of the dash underneath. Just remember what position the dials are in. Then, pull the bottom out. It's all held on by clips. You can use a flat screwdriver if you have to, just try not to mess up the dash
