How to remove b-pillar cover?
clicknext
2006 Tungsten Grey Mazda6 GT I4
Does anyone know how to remove the B-pillar cover? I'm trying to figure out how to install EL door sills and some how-to's seem to say that the grounds should be tapped into something that's on the driver's side B-pillar.
Thanks!
i just pulle mine off, it just had some snap things on it, but i wasn't trying to get it all the way off, but it should be enough to find a ground spot.
Ah, thanks.
It seemed really solid and stuck on there, but it just ended up taking a bit of pressure in the right spot. I first pulled the top-rear edge out, the part that wraps around and faces the outside of the car. Then I used that leverage to slowly go downwards and remove the entire rear side, and the whole cover came off easily after that.
As for finding a ground spot, I needed to actually splice the door sill wires into the door switch so that the sills would only come on when the doors were open.
Oh yeah for sure, here you go. Forgot to clean them before I took the pics! lol.
