How-To: Paint the inner headlight part
mx5_!an
1999 Mazda Miata
Here's a How-to I made a wile back to paint your inner headlights
on the miata head light you don't have to be to worried about making the seal 100% water tight considering the back side has little vents to let out the humidity.
i removed my bumper, makes removing the headlights a lot easier.
before placing in oven make sure all bulbs and accessories are removed (little vent things below)
Next set the oven to 200 and place the light on a cookie pan for 20 minutes
once pulled out use a flat blade screwdriver and pry one corner apart the pull back and the rest of it should easily separate
If you get it only half apart and it gets tuff, try sticking them back in for 5 minutes to warm up the glue again
Now remove the two screws holding in the inner piece of plastic that is to be painted
next i did some light sanding to help the paint stick (i used 180grit but used very light pressure)
Now a coat or two of primer
then some black (i used ultra flat black)
once the inner piece was reinstalled
next i put just the backing of the headlight ( the housing NOT the lens) back in the oven for 5 minutes at 200*
the reason being i wanted to warm up the glue so i could easily put the lens back in i also put a little bit of black silicone sealant hear and there.. were ever needed
the light back together
HID's reinstalled
and back in the car
Before and after pics
WOW i like it
something i shoulda done when i had my headlights apart
You should remove the orange/amber lens i did this on mine
Whats that white thing?
hey how long did it take to do the painting?
when i removed the amber bits in my headlight i musta left it in the oven for too long because those inner headlight bits sorta melted :'(
the whole project took about 3 hours...
i took out one of the orange pieces to see what it would look like but i like it better in.. plus there a lot brighter orange at night
alright heres my pics
I've also removed the orange lens awhile ago but I still got orange bulb
Ordered some chrome ones which flash orange last night so should be here by end of this week (they're not cheap :[ )
