DISCLAIMER:
1/This is ORIGINAL guideline from http://blog.sina.com.cn, not from my own
2/i will not be responsible or liable, directly or indirectly, in any way for any loss or damage of any kind incurred as a result of, or in connection with, your failure
ADVICE SEEKING:
I could have completed 95% of this retrofit, but could not understand the last step which required wiring to +/- switch. Anyone could chime in and help which wire and where to do so? thanks advance
OEM MAZDA PADDLE-SHIFT KIT
You would need to purchase this oem kit from your local dealership, or from taobao.com (as what i did)
Step 1:
STEERING WHEEL TAKE-OFF
These are tools which would be very helpful
Locate 3 screws behind the wheel. This pic below will demonstrate
Turn-on engine and steer the wheel to these positions, this well help to remove the
There are "springs" behind the airbag, we need to "unlock" the clip in-order-to remove airbag from the wheel, for details check-out pic below
DO NOT UNPLUG THE AIR-BAG FOR NOW
Step 2:
TAKE-OFF BATTERY
This is a very important step, we need to unplug the battery
Step 3:
AIR-BAG REMOVAL
Stock part are ready to install paddleshift kit
Secure the air-bag in safe place and be gentle while handling it
Step 4:
PADDLE SHIFT INSTALLATION
This is the paddle shift kit, comes with screws and wiring
Step 5:
PADDLE SHIFT WIRING
5.1
5.2 Take-off the steering column cover. This is required to access the wiring behind it
This shows the location of 2 plugs (left & right)
Closer-look
Wiring Diagram (this is the part i dont-know-how)
Plug "A"
Plug "B"
Wire
Step 6:
REVERSE INSTALLATION
ADVICE SEEKING:
Step 1:
Step 2:
TAKE-OFF BATTERY
Step 3:
AIR-BAG REMOVAL
Step 4:
Step 5:
PADDLE SHIFT WIRING
5.1
Closer-look
Plug "A"
Plug "B"
Wire
Step 6:
