no. never, if the rotors don't want to come off easily, you can thread a nut into the small hole in the rotor itself to break it off.
just so you know, there are two large bolts that you should remove for the caliper to come off. do not start loosening the nuts/bolts attached to the brake lines, if you leave them in place, you will not need to bleed your brakes after just changing rotors/pads.. take some zip ties and zip tie the caliper out of the way. DO NOT let the caliper hang from the brake line.
and good luck. if you have any questions along the way, post them up on here and someone should be able to walk you through.
fkmitsu said:oh ok then..... easy enoughwasnt sure if that giant nut in the center needed to com off
