daedalus said:I put mine on tonight with pics here:
http://www.msprotege.com/forum/showthread.php?t=123620970
evolv said:Mazda went through 5 sets of bushings trying to figure out how to prevent them from tearing apart. If polyurathane was the answer I'm sure they would have used them.
Because after 25 attempts, the dealer usually starts hassling you. Diamond Mazda wouldn't swap mine on the MP3 the very last time I tried (right before installing the Delsing kit). I never even bothered with the MSP (which was clunking when I bought it), I just installed the Delsing braackets.CHICO2003 said:for those still under warranty... why not just bring it in to the dealer?
It will last longer but isn't a permanent fix. The location of the mount is wrong, which causes the bushings to wear prematurely. The only permanent fix is to move the mount point out toward the wheels, as Racing Beat originally intended. When the new bracket kits are made, that will be the way to go.03MzdSpdSTP said:polyurathane won't wear out like soft rubber mazda uses. it should last the life if your car if you grease it every year.
peepsalot said:Could some sort of solid bearing be used instead of bushings, so it could never wear out? Their only purpose is to let the bar rotate a bit, right?
peepsalot said:I don't know, it seems like the flex is supposed to come from the torsion of the swaybar itself, not the deformation of it's bushings. How would it scrape the bar?
peepsalot said:I just figured from the bar clamp stops(whatever you call them) to the sides of the bushings that the bar was not designed to move side to side.
You would never be able to get a bearing on the bar. If the bar were a straight rod it would work, but it has flares and bends that you would never be able to get a bearing by.peepsalot said:Could some sort of solid bearing be used instead of bushings, so it could never wear out? Their only purpose is to let the bar rotate a bit, right?
peepsalot said:Yeah I was thinking about that. If there was a kind of bearing that could be split open or something.
Stormtrooper77 said:You could put the bushing of all bushings in there and the thing will still clunk, clang, squeak, break, shatter, you name it. The only solution so far is to move the bushings from the stock location.
TampaSport20 said:why couldnt you then just move the little rubber "stoppers" over and redrill and tap new holes for the brackets on the crossmember ???
