pdhaudio said:pull of plastic kick panel on right side of passenger side foot area. Ditto for left side passenger foot area.
-pull the carpet forward.
-with a 10mm DEEP socket, unbolt the 4 nuts on the metal plate you see.
-pull the plate out, flip it over, unbolt two 10mm nuts on one bracket, remove the bracket, and slide out the ECU. Now loosen the bolt from the wiring harness to the ECU.
-pull the wiring harness apart from the ECU.
-Now do everything in reverse to get it all back together.
katsmp3 said:no no thats all wrong.. All you need is a good crowbar. pry the carpet up. pry the box out. and ducktape it back together.
