Don't for one minute think this is a "30 minute" job though.
Just getting to the bolts involves removing the intake duct and various plugs and pipes and stuff.
Then you'll find the bolts are all but inaccessible to anybody with normal sized hands, and the throttle cable baulks access even more, precisely at the angle you need to get the spanner on.
Once you manage to wriggle a spanner over the bolt heads, you'll find they are bolted in tighter than a camel's arse in a sandstorm.
If you manage to pull the damn EGR valve off without losing any of the bolts/metal gasket, you'll probably need to soak it in penetrating fluid for an hour before attempting to undo the screws that hold it togehter, since these apparently are made of cheese and disintegrate at the first sign of torque.
Once cleaned and oiled, getting it back on is just as bad - I suggest one of those "grabbers" for when bolts and bits go flying into the nether regions of the engine compartment.
They give torque settings for the bolts, but there's barely the room to swing a mini-ratchet, let alone a torque wrench. I say just do them up as tight as you can with a spanner.
Total time to complete: 4 hours.
Total skinned knuckles: all of them
Total time wasted trying to fish out dropped bits from the engine: 1 hour
Total profanities uttered: Lots
Maybe I should just stick to my day job and let the grease monkeys handle this sort of stuff...
