How to do a Hard Launch?
Rev to around 2500-3000rpm, hold it there, then ease the clutch in while you gradually apply more pressure on the gas pedal. Practice that and fine tune it by not allowing it to bog down and not allowing excessive wheel spin. Oh, don't forget, push that magical dsc button before you do all this.
get a wot box, set it to 5500rpms.. dont turn off the dsc, let it 2step for 2sec nd drop the clutch, hold the gas down in first intill it stops spinning, then slam second hard nd let it spin again then slam third when 2nd stops spinning.. =] =] =] lmk how it goes lol
Don't turn off dsc = no spin.
Don't even try to launch hard in this car without mm at the track u will only get a whole lot of wheel hop. 2 step is the best set it aroun 3g and thn feather or "ride" the clutch a bit it takes a little practice but anyone with some coordination can do it
#1 rule learning to launch your ms3 - Ignore anyone that directs you to drop/dump/pop your clutch without a WOT Box/2 Step.
#1 rule learning to launching your ms3 - Ignore anyone that directs you to drop/dump/pop your clutch without a WOT Box/2 Step.
ya i always slip the clutch i just dont have it in me to rev it up to 4 k and dump it no race is worth that much to me all you do is spin the tires anyway
Yeap thats why i said 2k hold it then slip it to 2.8k ish and you should be off the clutch. You also need to look at it this way to... no matter how you launch the car your hurting it a little bit, just find the method which meets what your looking for
pm FMOSracing he is by far the most skilled!
check out the 1/4 mile with slip thread in the general section.
i feather the throttle and slip the clutch in first then sorta flat shift every other gear. when i do it well it works...but if i miss a shift i grind and blow the run...
my launch. is set the car right around 3300 rpm and preload the car slightly on the ebrake and clutch then feather the spin for boost and spin till 5500 and never lift the right foot. just clutch and shift
