How to decrease/fix/modify the wastegate actuator so it will limit at 6 psi?
IllaNoizeTV
2003 Mazdaspeed Protege
I believe my wga is not working properly. I'm not sure which component but pretty much it doesn't limit the boost to 6-7psi. It lets me go up to 10-12psi before hitting fuel cut. Should I buy a new wga (my last option) or is there a way to modify my original one to limit the boost to 6-7psi? I heard of bending the wga arm? Or cutting the arm, threading both sides then put a nut on it? I also heard of connecting a plastic T to the vacuum tube coming from the wga then having another tube coming from the extended T then cutting the extended tube until I get the right boost amount? Can anyone help please?
Eh if it's adjustable you have to adjust it outwards make it longer. And i have done the T but it also just adds boost
Sent from my iPhone using Tapatalk
