How to Datalog with ATR
dougefresh_
2006 MS6 wwp
I called Cobb today to get a ticket number to get my AP fixed, and also asked how to Datalog with ATR.
1. Uninstall ATR from your laptop
2. Plug your AP into the OBD port as usual
3. Plug your AP into your laptop via the micro USB to USB cord
4. Run the executible file of ATR.
This will install the right drivers so you can log with ATR on your laptop. He also said you get way more data points per second because you're using your computer's processor to capture data, and not the AP's (it has a small, slow processor). This is using the AP as a pass through device to get the data.
I had tried rigging my computer previously, but I kept getting some error message (I forget which) when I selected "connect to ECU." It was because I already had ATR installed on my laptop. So save that executible download file update boys, and uninstall it from you laptop if you want more data points per second, etc...
I hope this clears some things up!!!
