YellowPro5
when using the non fouler do you need to change out the o2 sensor???? to get it to keep from throwing the code again??
i don't believe so...
still no p0421 code for me
although i am getting p0300 code but that was after i installed my second motor... Still can't figure out whats causing the random misfires
I stopped at Salvo when I went for my cruise after finishing up today I heard some clacking coming from the underneath were the header bolts to the main cat and was thinking..damn thats not good! Thanks to RacerX I believe I know the problem. I love you guys!(headbang)Saweet
If its a little raspy check if its coming from where the header meets the mid pipe, If the header pipe pertrudes the O gasket on the end of the header you need to grab a sawzall or hack saw and make it flush, also use a torque wrench to tighten the bolts right (To the block with the torque wrench, & compress the springs a bit where it connects to the mid pipe, but if there is any bit of pertruding of the header past the O gasket, its most likely going to make raspy noise), there is no more bracket holding the header to the engine and it moves ALOT if not tightened right the raspyness gets louder and louder.
anyone know if these non-foulers are stainless?
haha...VERY nice write up man!!! great pics too
Wondering if you can help me out with the placement of the non fouler set up on my 2.5 V6 Millenium S.
Wondering if you can help me out with the placement of the non fouler set up on my 2.5 V6 Millenium S. My error code is PO420 - catalyst efficiency below threshold Bank 1. This is a California setup where the pre cat is not attached to the manifold but, is under the floorboard. My understanding is that Bank 1 is closest to the firewall. Do I place the modified O2 sensor in front of the pre cat or behind it? My guess is behind (or maybe it's on the pre cat itself). Please note that my objective is to pass smog (not fun in CA), install a new universal pre cat (high flow if it's appropriate) in its place and save a grand in the process.
Thanks for any help or suggestions you can give me.
Oh, and the reason I'm not taking any chances with the pre cat is that I blew a Ford 351 Cleveland motor in my RV ten years back because of a clogged cat. The CEL didn't come on at all and it ended up costing me over 4 grand. Some people on this thread seem to think that there's an inherent problem with the ECM "falsely indicates an emission concern" I'm not sure I want to take that chance. I'd respect your opinion on this if you have time to reply on this as well.
Thanks again, and if there's a special charity that I can donate $50 in your name, give me that info as well.
