Brian MP5T said:60 Has Foil on the wire...
LinuxRacr said:Mine had more of a rubber cover with a single strand of shielding wire going thru it.
dominoy2k1 said:it should show numbers on the ends of the wiring harness. . it should be like 1-40,41-80/81-120. something like that. check the picture.
Brian MP5T said:Ah, But it did have foil on it... (usa)
Mazdaspeed989 said:I installed my A/F guage today. I spliced into the Pink wire w/ blue stripe at the first O2 sensor and my guage jumps back and forth when i'm at idle. I just read into the thread about splicing into the second O2 sensor for a steadier reading so I will be doing that tomorrow. Hopefully it will keep it from jumping around so much. Also have an DSM's AFC on order so we'll see if that calms it down a bit too.
