How to activate speed limit visual as well as chime?
I owned a 2022 CX-5 Signature Turbo and loved the car so much and want to upgrade. The cost of the 2025 Signature Turbo equivalent however, is prohibitive and therefore I have to be ultra comfortable to accept a lower trim (probably the non-turbo.) I got a loaner/tester to get accustomed to the feel. So far, there is only one pet-peeve that I am having and this is the Speed limit chime.
I configured the 2022 model to chime when I am 10mph above the speed limit and have become so dependent on the feature. Despite having the Traffic Sign Recognition and Front Sensing Camera, this 2025 model however, does not show the option in the menu to activate the signs nor the chime. Neither am I able to see the speed limit in the HUD. It does have the extension of the map inserted from the Car Play Map. What seems to be the problem? This is a much loved option which is also deal breaker.
Does anyone know how to activate the speed limit visual as well as the chime?
Thanks in advance for the feedback...
Most likely you're missing the native navigation SD card. Without the card there is no speed limit.
Ask the dealer to insert a NAV SD card and see if the options you want appear. Speed limits are detected real time but you need the NAV card to get it started. I believe it reads speed limits from the NAV DBase until it detects a real sign.
No Speed Camera Warnings:
I've Gen 7 SATNAV, recently updated map.
Despite having Visual,+ Audio warnings enabled in camera settings NEITHER works - wish they'd sort asap.
Great news guys. I got a new map SD card from the dealer and as expected, there was no immediate apparent difference. After about 8-9 miles, I say the indication pop-up on the HUD as well as on the panel. Also, the chime works. So I am an event happier camper.
I discovered a new feature as well. The spec sheet doesn't mention it but the car does (I don't know the proper description but I will call it) engine start stop at a traffic signal for example. A pleasant surprise.
Well said. It works like a charm. Now I have the feature configured as was the case on the other car. (y)
Are you saying you like the Start/Stop?
