How much $ for Haltech E6X
We have the same flying lead kit for USD$1,100.00
It is not very simple to make the harness if you want to do it right. We remove about 40% of the wires as they are not needed in the proteges.
The flying lead kit does not come with any plugs or pins. You need to purchase the connectors/pins, MAP sensor which can easily be $80 to $100.
The wrong wiring can burn the unit just by turning the ignition on or causing it not to perform as it should.
We have them in stock.
Juan
the few dollars you will save(not really saving cuz it doesn't come with everything you need) isn't worth the extra work IMO of course...
yep...and after the price you gave me, you don't really save anything...
The kit from Haltech is an additional $200 for terminated harness and it will be a pain to install the terminated harness from Haltech. Right there the price would be $1,350 plus the Map sensor.
Here is a picture of one of our kits with injectors. It has an F10X but the wiring is almost the same.
not plug and play, as there are still wires to tie in... but as previously stated by Bryan there are only like 12 wires to solder. so its not too bad
ok, I sent an email to hiboost but I did not have an answer , because i need Haltech E6X for my protege 2001 (2.0L je piston 9.1.1,crower rod and turbo GT30R).how much complet kit with big injectors(880cc) and map 3bar?
and how much shipping quebec ,canada ?
thank you
