shane02pro5
25ish_psi
- New Caney TX
All that wire is doing is giving a TPS voltage reading it will not hurt anything by sharing the signal with both the AFC and J&S and telling it when to look for knock.
shane02pro5 said:The J&S should only intercept the spark if knock is detected and the TPS wire only lets it know when to start looking.
Your AFC is controlling the injectors. Two separate things that should not cause a problem. What other wires are used for your AFC? Do you have timing control with your AFC?
