How does this ZEX thing work?
MP5driva03
1995 Subaru Impreza AWD Wagon
I saw an ad in I think Super Street for a special filter with a braided steel cable protruding from the top, saying that this "ZEX true bolt-on nitrous kit" is the easiest to install (takes 15 minutes) and that it will supposedly add up to 90 hp. Is this nothing more than a bottle that sprays nitrous into your intake, so that the nitrous mixes with air and is injected likewise? Sounds like its almost too good to be true, and as much as I would like an easy NOS application, it doesn't sound like it would be good for the engine. I don't know much about this kinda stuff, so someone please enlighten me. Thanks.
what zex is, is a "dry kit," quoting pdhaudio:
DRY
By far the easiest to understand and use of all four types is the dry injection system so we will cover it first. Probably when you think of a street-car running nitrous you are thinking of this form of injection. Companies such as Zex and NOS have made dry systems extremely popular recently. Usually these systems are activated at wide-open throttle (WOT) and are almost as easy to use as just flooring the accelerator. A dry manifold injection system works by simply spraying only nitrous into the intake manifold. At this point, the cars fuel injectors must supply enough fuel to burn the additional oxygen.
Now, remembering what we learned earlier about fuel being the key to nitrous injection, we can see the biggest disadvantage to having a dry system. Because the cars fuel injectors are supplying the additional fuel the amount of power you can gain from a dry system is going to be limited. As a general rule of thumb you can only get a maximum of a 75 hp shot out of a dry system. Another common problem with dry kits is that they suffer from distribution problems, meaning that there is always the possibility that the cylinders will get an uneven amount of nitrous sprayed into them. This uneven distribution can cause the injection to be less potent. However, dry kits have some good advantages as well. As I mentioned above, dry kits are very easy to install and use so that means they are perfect for the nitrous beginner. Also if you opt for a Zex kit you get the benefit of a computer controlled safety module. Just be careful and do not let the safety features lure you into thinking that you are 100% safe from mishaps.
You must be talking about this:
I'm just about to watch a movie
remember if it sounds too good to be true it probably is.
I'll respond after i watch Bad Boys :)
LinuxRacr and Vulcanon, yall kick ass...and pdhaudio, you have my respect. How did you learn all that stuff? So if I were to buy that dry nitrous kit spoken about above, could I take it off and still pass the Mazda inspections and maybe not void the warranty? That would be so awesome...
Just remember that a dry shot without any fuel management is just asking for trouble. A wet shot is much safer because it adds fuel at the same time as you spray.
MP5driva03 said:
what do I need to do with fuel management? Or what would you recommend?
I'd just go with a wet kit. The success stories you hear have come from wet kits. I had a Zex dry shot on my MP3, and there went engine #1. Now keep in mind that the MP3 has some characteristics that added fuel to the fire (no pun intended...yes it was!! LOL!). The MP3 has advanced timing which is BAD for turbo/SC/Nitrous.
ok, im back- the ZEX Product is really BS, I mean, any nitrous dry and wet kit is a "simple" bolt on. HAVING SAID THAT, if you go by what ZEX says and do the install yourself, you are asking for trouble.
you may PM me or AIM me (pdhaudio83) at ANYTIME and ask questions :)
I read that article also..It was well writen...and is being marketed very well..
I am not really sure if ya wanna pick up a dry kit...THey really aren't 15 minute install...LOL...Just getting the bottle out to refill and putting it back in is almost 15 minute!!
Good luck with your choice...
P.S. I got a connection w/ NX Kits..Talk to phaudio for more info..I gave him all the details..and he already got his!
Zex is actually like a 30-45 minute install if you know what you are doing. It is in no way a long term thing though. Although I ran several bottles I would sugget wet but for a starter dry is ok, just don't make it an everyday thing. Save it for the track and you should be fine.
and dont push a dry kit, remembering the more nitrous you shoot the more fuel your pump and rest of the car is going to have to make up for it....
