Outlawstar98
- 2003 MazdaSpeed Protege / 2013 BRZ
-Focus SVT - never drove it, its a ford id suspect it to suck
Um... ford owns mazda the last time i checked
http://youtube.com/watch?v=oQM1NUmK3qA
umm i disagree with the rsx is heavier thing cuz i know for a fact the weight is 2506 curb and ours is 2800 or so.and tha rsx handles like its on rails oh and i wish our car went to 9500k that also makes it amazing so don't dis the rsx
You have to keep in mind that AWD doesn't mean better handling. All AWD is good for is straight line traction. Don't get me wrong, the MS6 is a good handling car, but not better than the Msp.
I have to disagree there. AWD certainly helps traction under many cercumstances. There is a reason that mitsubishi subaru and nissan all use it in thier top performance cars. Non of them were designed to be drag racers and all use complex control systems to get every thing possible out of the AWD.
Some cars actualy let you feel the AWD working when you push a car hard enough through the twistys.
I feel that AWD is just extra weight. Nothing beats a proper RWD setup. But I do respect your opinion.
In the local street-prepped track series (race-track, mind you... but more technical than high speed), prepped front drivers often post quicker times than prepped AWD cars.
An AWD car has awesome grip, and you can get some awfully good slip angles out of an AWD car in a corner drift... but on the race-track, the racing line is still (and always will be) the fastest way through the corner... and an AWD is often heavier and more understeer-y in the tightest corners.
Outright lap records for street cars on the most technical tracks we have over here are often in the hands of lightweight turbo-charged Hondas. Hell... they're even starting to make a mark in the autocross and slalom series... one slalom event was won by a well-prepped Civic hatchback... this is against a hardcore field of RWD Toyota Starlets (1000 lbs + rollcage + full TRD set-up + straight pipe = wicked).
Cornering is suspension, suspension, suspension. FWD-AWD-RWD just dictates when and how hard you can get back on the gas.Of course, in this case, FWD sucks balls... but a good set-up can mitigate this. Anybody who argues that RWD is better because you can use the throttle to rotate the car has to bear in mind that F1 has traction control for a reason... you can definitely have too much of a good thing.
so if one wanted to "tighten-up" the msp suspension what would be some necessary steps?
You'd need to install stiffer struts and springs. A rear strut bar helps to bring the rear end even more together. Very easy and solid mod.
Guys, we forgot to mention the Celica GTS as a contender. I believe it was Whiteline who was able to achieve a 76mph in the slalom with a few suspension mods!
The MS proto really wouldnt need a rear STB it allready has a piece of the unibody structure there. Only the wagon has room.
Yeah I'm bumping a month dead thread.
Depends on what you consider better handling......
If you want something that handles great if you now how to drive it or understeers like crazy if you don't, ya then pick the Type R.
But personally I like the neutral handling of the MSP.
