it's not just handling, but with the stock tires, you won't stop...the ABS is doing what it is meant to do...keep the wheels rolling while slowing vs locking up and having no control. The stock tires will turn so hard in freezing temps that you will litterally thump along until they warm up if you park it overnight outside in cold weather. They can't grip at all and thus will not give you any stopping power. The Stability system is out the door too as it using braking power.
sure, you manually locked up the rear brakes to plow forward and create friciton and causing the car to stall helped too.
Black ice perhaps? Sounds exactly like what happens on frozen roads. Road doesn't have to be shiny to have black ice present.
not necessarily. Locking up the tires created heat and friction between the road and the tire compound. ABS doesn't do that and isn't meant to. It's meant to maintain steering control. Personally I've found threshold braking better than stomping on the brakes and engaging ABS but that's just me. I hardly ever have ABS to kick in and we just got blasted with ice and 8" of snow. Zero issues with starting or stopping........the difference......LM-25's. /story.
Can't comment on such a practice.
