HKS Turbo Timer
mp3moose
mp3 and elise
Yeah, so I am sitting on a brand new HKS Turbo Timer type 1 and I got no turbo. I got it for very little $ and wondered if it were worth it to install on my NA mp3. I wouldn't need to have it run the engine after shut off and cool a turbo....however, it does provide realtime digital speed readout as well as realtime 0-60 and 1/4 mile times....:D Unfortunately I have neither the elecrtical knowledge nor the tech skill for hooking it up. So, since HKS doesn't provide the wiring diagrams for a 3 or a protege, does that mean it won't work with our set up? Help me out guys!
Cheers
It will work on our cars, there should be a universal wiring diagram. And if that does not work there is always ebay;)
The install of the turbo timer alone isn't that hard just use the diagrams given with the timer and a voltmeter to isolate the wires thats all i did with my Blitz timer...took me all of 30 minutes to install. Just remember when you turn the key to the On position there is 2 wires taht the ingition sends a hot signal too that both of these wires are the run wires not like most cars that only have one run wire ours have 2 so you have to connect the run wire on the turbo timer to both of the run wires or it wont' do anything.
