For those who may be interested I'm attaching three accelerometer charts that can answer many questions about rpm v. speed and time vs. speed v. g-forces (power to the ground).
An accelerometer, especially one comparing acceleration rate to engine rpm, is a different form of tuning tool that gives you some additional real world data beyond a static chassis dyno or a drag strip timer slip on how you car is actually putting its power to the road.
Accelerometer numbers are not to be taken literally (any more than dyno numbers can), but a good one, like the one that made these charts, can get time and speed almost perfectly and get within a tenth of a second in the quarter. It can tell you a lot of information about the true relationships between engine rpm, time, speed, and traction. This includes whether and when you are getting wheel spin, whether you are doing lift throttle shifts or power(flat) shifts, how much time you spend in each gear, at what rpm the shift actually occurred, and how the time in each gear combines to produce a 0-60 time, a 0-100 time, a 60 ft. time , a quarter mile time, or any other relationship between time and acceleration rate that you want to measure. You can see how gearing affects acceleration and how aerodynamics affect performance (something very useful that a chassis dyno cannot measure).
Talk amongst yourselves:
