ok let me rephrase the first post. Basically what I wanna know is what the stock piston compression ratio is, also if anyone has put lower compression pistons in and if you had any problems with that. What are some of my different choices on pistons,rods,and cranks. Also if anyone has upgraded thier turbo or modified the stock turbo, just curious what that has done and if there were any problems with that. Finally If anyone has put in performance cams and same questions if you had any problems with that and so on...
thanks for your time, sorry so many questions.
