well i would reccomend just replacing all your vac lines (or at least the smaller ones off the intake mani and to the bypass valve and wastegate) with high quality silicone stuff. Mazda used fuel line for vac stuff, which isn't designed for all the levels of heat in the engine bay (our cars seem to get particularly hot under there), which leads to them deteriorating. Also make sure you check out your wastegate actuator.... find the vac line running to your WGA, pull it off the tee, and blow into it. If air goes through, that means your wastegate actuator diaphragm is torn (or that vac line is crap). Either way, that can be a big cause of boost/vac leak. ATP makes a replacement thats much cheaper than the OEM, you can get one from www.*************.com if that is in fact your problem. They also sell quality vacuum line. Be careful with what silicone vac line you go with, because if you buy cheap stuff it is known to sometimes collapse, restricting air.
