Hiboost Turbo Kit Roll Call
YP5 Toronto
Contributor
(Lets see if we can actually have a clean thread)
I find myself being surprised at members with Hiboost kits by reading people's sigs.
So... I don't think has been done before. Post ONLY if you are a Hiboost Turbo Kit Owner and your surrounding mods engine based (BOV, Injectors, E6X/F10, piping, etc) .
I'll Start
Base Kit with
Haltech F10
440cc Injectors
HKS BOV
Ceramic Coated Turbo Housing, Manifold and DP
Hiboost 8.5:1 Compression Pistons (Ceramic Coated, coated skirts)
3" Piping turbo back
High Flow Car
3" Titanium Muffler
I think I have some 40,000K on the kit and not so much as a bolt has come loose.
One Pic (don't mind the yellow and blue hoses...I have since changed to all BLUE)
http://www.msprotege.com/members/YP5%20Toronto/importfest/importfest_7.JPG
<--- Raises hand.
Base Kit
Haltech F10a
HKS SSQV
Racing Beat catback (from when I was NA)
And thats it, unless you count the new NGK Iridium plugs I just put it. I will also soon be the proud owner of the new intake that Juan has designed. I also have the haltech boost controller, but it isn't hooked up.
No pics. My engine bay is permantly filthy. Trust me.
If we count,
2002.5 Protege 5 Turbo
HiBoost turbo Kit
Haltech E6X upgrade
HKS SSQV BOV
8.5 to 1 Pistons
Pauter Rods
ACT Heavy Duty PP with organic disc
Larger RC 440cc injectors
Bosal 2.25 Cat back
Eiback springs
To be installed and in the shelf:
Ported and polished head with larger Intake and Exhaust valves
MSP tranny
MSP Axles
BIG BOOST kit with GT30R and Larger Manifold
base kit
Greddy TypeRS bov
Aem CAI
wrx 440 injectors
3in midpipe
oh and one more thing, have any of you had problems with the throttle body BOV pipe hitting the master cylinder???
LinuxRacr just linked me to this thread so I will take a break from my homework to add to the list.
Haltech E6X
440cc RC injectors
HKS SSQV
Boost Controller
Ceramic coated jet black everything to the downpipe with some product called TurboX 2000 or something like that (good to 2000 degrees)
2.5 turbo back crush bent with only a resonator
PWR Radiator
Stock rods and pistons for now
Stock clutch until I can afford an upgrade
8-9 psi daily, I have turned it up to 15 but the stock clutch didnt like that at all.
I would say I have maybe 2k miles on the kit now. I installed it after a major wreck ($8k in damages) and the car started right up no problem. Not a single problem with the kit other than an idle problem on restart but I have traced that to a bad vacc tap. So far I love the kit! Very solid, not a single worry so far and I dont expect one.
Lots of pics: http://www.vividyellow.com/gallery/thumbnails.php?album=7
The first kit sold.....;)
1. F10
2. Haltech boost controller
3. HKS SSQ BOV
4. JET HOT coated
240whp at 12psi
yes, I cut the hose shorter and solved the problem....(naughty)
1. F10
3. HKS SSQ BOV
4. JET HOT coated
240whp at 12psi
This has since moved to here. But it doesn't look as nice
1. F10
3. HKS SSQ BOV
4. JET HOT coated
5. 2.5" Racing Beat exhaust with 2.5" mid pipe
The car started up right after everything was connected and with no problems since.
PIRANA: you cut the hose shorter??? how did that solve it??? it wont connect up then would it?
I think you guys are talking apples and oranges: Hiboost Turbo Kit vs Hibbost FMIC.
hahahah yeah no talking!
ok here goes
Base Kit w/ F10
Greddy Type S BOV
soon to have the new intake design since the old one is breaking my coilpacks and chafing my wires
Greddy Profec B II Boost Controller run 6psi daily... bump up to 8 once and awhile Auto Tranny :(
Greddy Evo Catback (from n/a days)
Here's a pic right after install pre Greddy BOV (imagine a big purple shiny thing where the cheap HKS one is) i have the stock spark plug wires on there now too
base kit
haltech f10x
act street/strip clutch
corksport power series exhaust
corksport tb
Deckedoutmp5's kit ;) (now mine)
base kit
haltech f10
440 injectors
2.25" Magnaflow catback exhaust
2.5" midpipe
transmission cooler
hks ssqv
on the way: upgraded throttle body, new boost controller
Former HiBoost owner here. Heres a pic and specs anyways:
Base kit + HKS SSQV, RC440 Injectors, E6X upgrade
Ceramic Coated in TurboX2000
2.5 inch crush bent from the turbo DP all the way to the muffler (no name)
On the dyno I only made about 240 I think (I may be remembering wrong) because I was slipping at anything over 8 psi.
Gotta throw in the old Haltech screen in there too.. heh
25,000 Miles on it
Standard kit
F10 @ 9.5PSI HKS SSQV
Clutchmasters Stage IIR
Custom 2-1/2" Mid-pipe
2-1/2" SS Catback
Custom Poly Motor Mounts
Newly replaced 03 Tranny
