Hi, needs help with making decision of picking wheels and ties
Hi everyone I have some questions for selecting wheels, ties and springs for my True Red Mazda 3S, 2.3L 2007
Bolt Pattern: 5X114.3, ties size: 205/50/R17
I have chosen a wheels for my car, below is the link and image of it :
http://www.1010tires.com/wheel.asp?w...442-880-6540HS
This wheel has same bot pattern available for my car, off set is 40mm. But I believe my car's offset is about 45+ I am not sure. If it will fit to my car?
And any buddy has suggestions for other wheel?
How low I can lower my car if I don't want any rubbing? 1.8 drop? 1.5 ? 1.4?
Is it too much to have 1.8 drop? I like eibach so much but they currently only offering 1.8 drop and 1.2 drop, if 1.8 is too much then 1.2 will be not low enough then.... B&G has 1.4 drop available but I am not sure if B & G is good, anyone can tell me which brand is good except eibach?.....
Talk about ties, I am living in Florida and the temperature are constantly above 25 degree C and even above 30 C in summer. Should I pick a summer tie or a all season tie? Is there any brand reliable but averagely cheaper? Does it look okay if I put a 225/40/18 tie on my wheel ?
Sorry for having too much question! I hope any professional can answer me.
THANKS
link doesnt work, try a different one
and all season tires would be better, they normally tend to last longer then summer tires
but if u like to drive aggressive then get a high performance all season tire, may not last as long though
and as for the drop, i have no clue about mazda 3s so i couldnt tell ya lol
the stock offset on your car is +52.5
if you go with a +40 offset you will not be able to lower your car at all without rolling your rear fenders. look for a wheel that is +45 or +48 and you'll be far better off.
