Hi-Flow Cat with Cat Back Exhaust
what do you mean install on the stock exhaust? the corksport exhaust replaces the stock exhaust. and yes, that exhaust yielded a significant gain in power. search around and you'll probably find a dyno or something.
I mean, its not a full exhaust system, its just the s pipe. Do i need to add a full cat back, and muffer to get the full benefit?
I believe the cork sport down pipe is the s pipe and a short pipe that bolts to the cats their exhaust replaces the cats all the way out the back. With both pieces it becomes a true turbo back exhaust.
Rawyzf said:
I'm in the St. Paul area.
The vibrant exhaust replaces everything from the S pipe back. I don't know if it will work for you unless you have the same turbo set up as the MSP....unless the MP3 exhaust starts with a J like the MSP...(huh)
I have a high flow cat in mine. It is loud though, you would distrub your neighbors and you will also get some backfire. Not ricey loud though, sounds pretty deep.
People have said the corksport is louder than the Vibrant. Do you get any droning? How is cabin noise?
I think the Vibrant is louder, and yes there is cabin noise.
