mp3wannabe said:CV joint?
mp3wannabe said:its the axle to wheel joint. it will make a clicking noise if its gone.
turn the wheel all the way one way and reverse or go forward. I you hear the clicking sound then your cv joints are out.nadim said:yeah probable that is ,how to check for it???
Long enough, it will lock up!Caedmon7777 said:if you ride on a bad cv joint too long what happens? anything bad?
Chawk said:usually when you wait along time to fix a tore up cv axle you start two hear a popping noise like firecrackers going off under your car, thats when you know the thing has to be replaced. as for the 2 metals touching each other that doesen't sound like a cv joint problem to me i would check the motor mounts.
