Hi everybody! Well, I have been messing around with my rear sway bar bushings for the last couple of weeks, and had the dealership finally put on some of the poly-eurethane bushings for the rear. They worked fine, for about a week, and then started squeeking real bad. So I tried one of the fixes I heard, and put some elec. tape around the bar in between the bushing, and greased the hell out of it, but when I was tightening one of the bottom bolts, the tapped hole stripped (I believe it's the hole, because the other bots don't tighten on that one hole) and now I get a SUPER KLUNK due to the bracket hitting the metal. Now, I'm not a genious at tapping holes, but how would I re-tap the 14mm hole? Would I have to go a size bigger, like a 15mm? Any help would be nice.
