canada1411
Hi all,
I'm brand new here so I tried in vain to find the answer to my question by searching this forum and using the net first.
I'm trying to buy used rims/tires on Craiglist, but am having trouble figuring out what would fit. If I had the 5 bolt P5 it would be easy to get the OEM rims, but I'm stuck with 4 bolt. Damn.
I'm looking for either 15inch/16inch rims since I have winter tires on steelies(195/55/15), and can get a great deal on used rims/tires online.
I know I need 4 bolt pattern/100mm I think, but I think that means 114 won't work. I'm not sure what offset I need though.
I also know that I'm stuck with drum brakes in the back, and discs in the front, and am not sure how that might affect mounting a rim?
I found one set I like online, the specs are 16inch Advanti alloy, 4 boltx100, offset=40, with summer Kumho tires 205/45/ZR16. I understand these tires are wider than my current ones, with a smaller aspect ratio. I'm not sure if their are more stats that I would need to get from the owner to find out if they would fit?
Any help from the Protege community would be appreciated, especially anyone with the LX with the 4 bolts.
Thanks(drive)
Thanks(drive)
