help with my MSP dying
Rosskie
Mazdaspeed protege
ok need some help.
started to drive the car and it died while driving. tried to restart did not want to start. so waited a little tried to start it and it did but started to drive again and put some boost on it to see what it could be. and it started to stutter and die again.
anything would help. from the fresh forged build i already put on 300 or less anything would help
Could be a lot of things, dying battery, failing alternator, loose connection at the battery or a ground, vac leak, loose fuse/relay. If the motor was just swapped it's likely something under the hood coming unplugged
Similar Threads and Articles
