I bought one of those T fitting coolant flush kits. Out heater cores seem to be in a poor spot for this. What the best spot to splice that in?
I was thinking about using the little rubber elbow location on the front drive side?
I was also contemplating another method though. Can I just disconnect both radiator hoses, and run a garden hose in the top rad. hose and then the opposite way in top of the engine where I disconnected it?
Will a garden hose run enough water that I can just undo one radiator hose and run the engine?
