Help with a Camber kit??
808Mazda3
Mazda 3 HB
I just installed a set of Tein Basic Damper Coilovers, and my ride shakes in the front at high speeds. I had it alined, and all, and it still kinda shakes.. I was looking into Camber bolts, but not sure if that would help. Or is there a front camber kit from the Mazda 3? Can anyone help me out? Thanks
Shaking as in like a slightly bumpy up and down shake or side to side. Kuz mine was doing like a little up and down motion like i was hitting alot of very small annoying bumps and the dealership said its kuz one or two of my engine mounts was broken or worn badly and i think that the drop just intensifies it. when i got my AWR it pretty much all stopped but i still get a slight shimmy in the steering wheel.
And like ninja said you might have slung a wheel weight.
To answer your question: No, there isn't a camber kit for the front. If the coilovers didn't come with adjustable top mounts, then you're out of luck. Generally the camber doesn't change much on a MacPherson strut, though. And the camber being off definitely wouldn't cause a shake. Caster might but not camber. I'd make sure that everything is tightened properly and also check the wheel balance, as mentioned previously.
