Help with 0 - 60 limiter
chasey
Mazdaspeed 3
Hi I am from New Zealand and have a mazdaspeed axela (JDM version of mazdaspeed 3) the Japanese are not making any after market ecu as far as im aware for my car and the USA versions of hypertech and cobb wont work on JDM ecu im pretty sure. Can any one tell me if one of these boost cut killer modules will remove the boost cut problem the MS3 has in 1st and 2nd gear so I have full power the in every gear? or has any one got any other ideas?
Your help would be much appreciated. Thanks
ATP Boost Cut Killer Module,Mazdaspeed6/mazdaspeed3/CX7
No. It is in the tune. You could try a manual boost controller. If you do, be careful as you are bypassing engine safety systems. I'd keep it set at stock boost and no more than 18 psi max after working up to it.
thanks I checked there web site and it appears they do it for international market. cheers
