i get bouncing rpm between 500-1000 when back into neutral after high speed(high way speed),it doesnt do that on lower speed (like local speed limited).no cel yet, vacuum leak? i mean my boost gauge is shown 20 vacuum, recently just swapped the turbo(which is bad turbo too), and i did the non fouler trick to avoid that CEL(would this trick cause the CEL not to be shown eventhough if i have a leakage or something bad?) any help will be truly appreciated!!!
