Help running AMP kit???? MS3
ms6utah
MS3 Cosmic Blue & MS6 Black Mica
Can anyone help me. I'm trying to run my amp kit and can't find a location in the firewall. either I'm blind or not looking hard enough. Thanks(uhm)
I know this sounds kind of lame but the way I ran my kit is pretty simple. I ran the power cord from the battery inside the drivers quarter panel, I removed the side skirt and tucked it in, replaced the side skirt with the cord inside of it and shaped some straight plane old aluminum brackets from home depot, 3 in long by .5 inch worked. I screwed the brackets into the wheel well of the rear drivers side wheel. They're doing a fabulous job of holding the cord in place. I put a plastic wire loom, that tube stuff that protects wires, around the power cord. I ran in through a half inch hole that I drilled in the tire well from the compartment that holds the jack. I ran the cord underneath everything and to the amp. I sealed the hole with black gasket gunk from autozone. Looks good it's almost completely hidden unless you pop the hood but my wire is covered and concealed. Looks stock real simple.
There's a large grommett behind the glove box where the major harness runs through, plenty of room for up to 4 gauge wire. Do a search, there are install guides with pictures.
Similar Threads and Articles
