Run for Cover
- 2003.5 speed
Ok so i have a mazdaspeed protege.. the rims i TRIED to put on are the ASA JH8's which tirerack sells for our cars.. here is the link http://www.tirerack.com/servlet/Cal...ex=0&filterSize=&filterFinish=&filterSpecial=
Size Selected: 17x7.5
Price: $159 (each)
Estimated Availability: In Stock
Recommended Tire Size: 215/45-17
Wheel Offset: +50mm
** Lightweight: 19.6 lbs. **
Additional Specs
Bolt Pattern: 5-114
the front rims rub against the calipers BIG time.. its like i need spacers or something.. i have to call tirerack sometime this week.. anyone ever expereince something like this? are those rims the wrong size? thanks...
Price: $159 (each)
Wheel Offset: +50mm
Additional Specs
Bolt Pattern: 5-114
