Help please!!!! Fellow MSP down
I replaced coils, wires, and plugs last night. Car seems pretty good right now. I reset the ECU too, so we will see if the code come back. Seems like a get smoother starts from 1st gear for right now. It did seem like the car had a little trouble getting up to speed before replacing everything.
Ok cool, keep me updated
Hows it going blkonblkMSP. Been a little while but replacing coils, wires, and plugs seemed to work well for me. Just wanted to make sure you tracked down your problem.
What about 92 octane?
it could be a number of things
1) bad or clogged injector
solution: replace bad injector or run seafoam or other gas
treatment/injector cleaner
2) wrong gap on new spark plugs
3) faulty wires
4) faulty coils
5) wrong type of gas( 93+ only)
6) bad MAF (this will cause fuel cuts as well)
check from cheapest to fix to most expensive until you fix the problem.
