help!! oil leaking from axle?
wldchld
it appears that i have an oil leak from the axle on the driver side and its making a mess of my engine area. any advice other than im gonna get hepatitis b?
Output seal needs to be replaced.
Fairly simple job, but lots of work to get to the point where the $8 part can be changed.
The Driveshaft has to be removed from the Diff Housing, To do that, some of the suspension has to be brought down.
