ok, so today i ran into an issue. i noticed that as long as the volume remains below 34 everything functions perfectly. as soon as you reach 35 you get a drastic change in volume and the sound level jumps up and down wicked bad. at this point im unsure if its an issue with my stock bose head unit or if the new PAC AOEM MAZ2 adaptor is not working properly. im currently running and aftermarket 8" sub and mono amp off the rear preamp outputs and another aftermarket 4 channel amp with 4 aftermarket speakers off of the front preamp outputs, signal wire for amps running from the PAC AOEM MAZ2, so the only part of the bose system left is the head unit. any thoughts would be great.
