I was intalling a rmm on my 08 ms3. I removed the bolt on the mount and the bolt attached to the bracket. Rather than tryin to break those 19 mm bolts on the bracket i decided to push the motot up w a floor jack and slide the rmm out at a 45 degree angle. As i raised the motor i heard a bolt snap somewhere and now the motor does not flex down to its normal position. Is this a common mistake? What is the worst that could have snapped when raising the motor from below?
Please help
Please help
